jziggity
Jul 04, 2025Tutor
Use ProSafe switch as unmanaged?
This is probably a very niche setup request, but I am looking to acquire a gently used 48 port unmanaged switch for home use. I currently have a D-Link 24 port unmanaged switch, which still works fi...
- Jul 06, 2025
jziggity wrote:
Is it really that easy?
Yes. The reset takes you back to the default config - which works perfectly as an unmanaged switch. Changing the management password is a security precaution (intended to prevent a bad actor on your network from changing the switch behavior).
schumaku
Jul 04, 2025Guru - Experienced User
Welcome to the NEtgear Community jziggity !
There are many Netgear ProSafe switch models with very different capabilities and features in the second use market.
In general, all are very likely operating by default on most ports like unmanaged switches.
To avoid any unexpected security issues, it's strongly suggested to take control, configure your own password, ensure there is the latest firmware available in place.
For inexperienced buyers, I would vote against buying into managed switches, stick to the more consumer-friendly Smart Managed models, and avoid stackable switches.
Better ask than sorry before buying!
-Kurt.
PS. To give you a wider coverage (sure, I see you referred to a S3300 Managed Switch model KB entry) I've moved your post from the Managed Switch section to the wider open Easy Smart, Plus, and Smart Switches community section.
