bjmango
Mar 23, 2018Aspirant
Using command line to control internet access on each device port
I am looking for a network device. It should allow me to use command line (telnet) to control the internet access per each swither port.
Which model network device could fit my needs? Will GS108Tv2 work for me? Thanks.
Hi @bjmango,
Welcome to the community!
The GS108Tv2 does not support command line interface (CLI) commands. It supports ACL (Access Control List) wherein you can allow or deny access such as HTTP or FTP. Kindly access the article below:
What are Access Control Lists (ACLs) and how do they work with my managed switch?
Since you want to use command line interface (CLI) commands, I suggest you check the NETGEAR Fully Managed Switch models on the link below. The NETGEAR Fully Managed Switch models also support ACL.
NETGEAR Fully Managed Switches
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Hi @bjmango,
DaneA
