PB21UK
Aug 03, 2023Tutor
Vlan advanced 802.1Q on Jgs524PE
I have read the manual and created some vlans but I couldnt figure out how to get the vlans to access the internat which in my case comes in on a router with no vlan capability which is on port 13. I...
JulienR
Aug 04, 2023Administrator
Hi PB21UK,
The VLAN capability of the Orbi allows the traffic from the ISP to bypass the router's Network Address Translation specifically for the purpose of IPTV (Page 84 of user manual).
You will need a switch with layer 3 functions, or a VLAN aware router to achieve your configuration.
Best Regards,
Julien R.
