hassan_r
Oct 19, 2017Aspirant
vlan between GS724Tv4 and virtualized pfsense
Hi pfsense router on esxi 6 host with 2 nics Ip 192.168.1.1/255.255.255.0 em0 asigned to wan (isp modem), and em1 asigned to lan, em1 connected to port 24 on Netgear switch GS724Tv4. Working perfe...
JohnC_V
Oct 20, 2017NETGEAR Employee Retired
Hi hassan_r,
Welcome to our community!
As per checking in here that your computer is still receiving an IP from VLAN 1. As I checked your configuration, the PVID is still set to VLAN 1 on port 20. Basically, If it is a T or TAGGED port, this means that this port was set to trunk. If it is UNTAGGED or U, then it will be an access port and you should also set the PVID to specific VLAN to where you wanted it to pass through.
You were also saying that you connected your computer to port 20. But the assignment that you had on the image was set to port 22.
You should've set port 20 - U, PVID 15 under Port PVID Configuration. You may also remove the VLAN TAG 15 on port 20 as it is already on PVID 15.
