hassan_r
Oct 19, 2017Aspirant
vlan between GS724Tv4 and virtualized pfsense
Hi pfsense router on esxi 6 host with 2 nics Ip 192.168.1.1/255.255.255.0 em0 asigned to wan (isp modem), and em1 asigned to lan, em1 connected to port 24 on Netgear switch GS724Tv4. Working perfe...
JohnC_V
Oct 23, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
