infologicit
Jul 22, 2017Tutor
VLAN configuration - GS728TP
I have three Netgear GS728TP PoE smart switches, linked in a chain by fibre optic cables as they are in different locations around the site, more than 100 metres apart. In switch1 I have a VLAN-aware...
- Jul 23, 2017
Hi infologicit,
Welcome to the community! :)
Let me share the article below and used it as your reference guide:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
infologicit
Jul 25, 2017Tutor
Hi DaneA
Thanks for the link, that answered a lot of questions for me. My setup is slightly more complicated than the example, with three switches involved, with the PC being connected to switch 3 and the router connected to switch 1. Are there any further things that I need to consider with having three switches? I notice that under the section heading "To assign the ports and set the port VLAN IDs:", point 3 the screenshot shows port 1 has been tagged. Do I need to tag any ports on any of the three switches?
Thanks
David
DaneA
Jul 25, 2017NETGEAR Employee Retired
The ports connecting the switches should be set as tagged ports because its a trunk link. For example: port 5 of Switch 1 is connected to port 5 of Switch 2. Then, port 6 of Switch 2 is connected to port 6 of Switch 3. Port 5 of both Switch 1 and Switch 2 should be set as tagged port with a PVID of 1 and should be a member of all VLANs. The same goes with port 6 of both Switch 2 and Switch 3 should also be set as tagged port with a PVID of 1 and should be a member of all VLANs.
Kindly refer to the article below:
How do I setup a VLAN trunk link between two NETGEAR switches?
DaneA
- infologicitJul 28, 2017Tutor
Thanks DaneA, that worked a treat!
