Chrispybacon
Jul 25, 2021Tutor
VLAN Configuration
Good morning, I have a GS308T that I am trying to configure and I am having difficulty. I need one physical port (port 1) to connect to my router as the trunk / access port for all traffic to the I...
- Jul 29, 2021
tmittelstaedt wrote:
I think it's more the marketing people telling the engineers what to stick in there.
The PVID config option might exist just so they can say it exists, not because they intend it to be used.
Considering the presence (and requirement) to not forget to configure the PVID to send the untgged ingress to the correct VLAN is probably the #1 VLAN switch support issue .... figure.
tmittelstaedt
Jul 29, 2021Star
Right - but since Netgear does not support it, I'm not going to send him down that rabbithole.
He COULD duplicate the functionality - somewhat - with the switch he has. Or he could buy a Catalyst from Cisco and run real RFC5517 PVLANs.
I've dealt with this sort of thing before with large DSL deployments. It is NOT simple. Troubleshooting is a real itch-bay since simple things like sending a ping you don't know if it's being blocked by a filter or the device just isn't responding. It's justified by the scenario outlined by Cisco in RFC5517 where you are dealing with extremely scarce public IP numbering and you must use every last IP. It's NOT justified by a collection of $50 devices in a home to satisfy someone's particularly paranoid tinfoil hatter scenario where everything is privately numbered and because it IS privately numbered you don't have to go down the "asymmectric VLAN" rabbithole because you can waste enormous amounts of private IP addressing and do it right.
All he needs is a convenient Linux box - heck he could use a Raspberri Pi - to create a REAL router, and he can define as many "traditional" private subnets as he wants on as many "traditional" VLANS as he wants, and route between them properly, like normal people without creating a tear-out-your-hair scenario.
There's solutions that belong at the carrier - like PVLANS, aka "asymmectric VLANS" - that need to STAY at the carrier. That's why Netgear isn't interested in supporting this sort of thing, because nobody with 4000 DSL customers needing isolation is going to be spending $1000 on a Netgear switch, they are going to be spending $20,000 on a carrier-grade product from Juniper or Cisco. Unfortuinately what so often happens in networking is people read about the esoteric stuff going on at the carrier level and think "that is so kewel I just gotta have it from my $50 network device I bought at Costco" they don't stop to think WHY things are done that way at the carrier and how much of a PIA they are to the admins working at the carrier.
Trust me if we had done things properly on the Internet in the beginning we would all be running IPv6 and nobody would give a tinker's dam about asymmectric VLANs or PVLANS or any of that. Back in my admin days with those DSL deployments I would have dropped all the layer2 filtering in a hot second if I could have just had a v6 allocation and sliced off /48's for my customers like cheese slices. What we did then was NOT something anyone with a brain would want to duplicate, it is NOT "kewel" by any means.
schumaku
Jul 29, 2021Guru - Experienced User
Hey I'm with you 8-)
But exactly the (unsupported?) asymmetric VLAN is the (only?) reason for having the crappy PVID config option on almost all Netgear switches. Because without, a port could be configured with only one [U]ntagged VLAN (actually it allows is to configure many), and a simple access port config for VLAN x would be much easier to understand for this customer base.
Somehow I think Netgear forgot about why things are speced and implemented as they are....
