meinit
Jun 26, 2020Tutor
VLAN ID limitation?
I'm configiring this switch for my network and the existing VLAN i need to connect it to is 100 . In the configuration, VLAN -> Port Based -> Advanced -> VLAN Identifier . The VLAN ID goes up...
- Jun 26, 2020
For fully flexible 802.1q VLAN config use VLAN -> 802.1Q -> Advanced etc.
schumaku
Jun 26, 2020Guru - Experienced User
