Makary
Mar 14, 2017Tutor
VLAN membership - Unable to tag/untag port member - GS748TS SWITCH
Hi all, selection frame ports - disappeared. I cannot tag/untag port members. Same story on browsers for Win10: IE, Microsoft Edge, Chrome, Firefox 52.0 and for iOS: Safari. Unit No. ...
- Mar 24, 2017
From my experience, one of these should work:
1. IE in compatibility view.
https://support.microsoft.com/en-us/help/2536204/how-to-use-compatibility-view-in-internet-explorer-9
2. Firefox 3.6.
3. Safari 5.1.7.KB article about this: https://kb.netgear.com/23841/The-VLAN-and-LAG-configuration-screens-do-not-display-correctly-on-my-switch
DaneA
Mar 14, 2017NETGEAR Employee Retired
Hi Makary,
Welcome to the community! :)
I suggest you to update the firmware of the GS748TS from v5.2.0.9 to v5.0.2.11. Be sure to perform a factory reset on the GS748TS after upgrading the firmware then reconfigure it from scratch. You can download firmware v5.0.2.11 here.
Let us know the results.
DaneA
NETGEAR Community Team
- DaneAMar 22, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to update the firmware of the GS748TS to v5.0.2.11 then perform a factory reset and reconfigure it from scratch? If yes, what is the result?
DaneA
NETGEAR Community Team- MakaryMar 22, 2017Tutor
Dear forum users,
sorry for the delay.
Tomorrow I will do the above. I will inform you promptly.
- MakaryMar 24, 2017Tutor
I restored GS748TS to factory default and finished firmware update too.
Unit No. Model Name Hardware Version Boot Version Software Version
1 GS748TS 00.00.01 1.0.2.0 V5.2.0.11 Frame is still missing.
Any other ideas?
- jak0lantashMar 24, 2017Mentor
2. Firefox 3.6.
