CrimpOn
Mar 27, 2025Guru - Experienced User
VLAN Puzzle
I would appreciate assistance diagnosing a VLAN problem. Now that many homes have Ethernet cables installed from most rooms to a central patch panel, some users find that the patch panel is not a gre...
Jul 09, 2025Guru - Experienced User
CrimpOn I see this was posted the other day. Wondering if you could check this with your 750 series and just one switch in the middle and see if VLAN ID 4093 works for you:
So far this is working for my BE systems accept for the 970 series in AP mode, which hasn't been changed over to the new GN subnet and VLAN ID 3890.
Let us know if you can re-check this with your system. I don't believe this will resolve the RBR in AP mode issue as I beleve the AX and AXE FW will need to see the same GN sub net and VLAN ID change as well. However router mode should still work. This is all with just ONE switch and not two.
