WildfireTech
Jan 11, 2026Guide
VLAN Routing for Newbies
Howdy All, I've recently decided to install a GS752 switch in our offices to segregate traffic to help with security. I've run into a problem that I'm hoping someone can help me with (to keep th...
WildfireTech
Jan 12, 2026Guide
Another QUICK question:
ALL of my ports in ALL VLANS are "U"ntagged.
VLAN 1 - U - Ports 1-10
VLAN 10 - U - Ports 1, 11-25
VLAN 20 - U - Ports 1, 27-39
VLAN 30 - U - Ports 41-47 (Isolated)
schumaku
Jan 12, 2026Guru - Experienced User
WildfireTech wrote:ALL of my ports in ALL VLANS are "U"ntagged.
This looks like a highly illegal configuration to me. The same port 1 can't be in multiple VLANs as [U]ntagged.
Do you expect that any outgoing frames for all these VLAN 1, 10, and 20 can come out of the port 1?
What have you set for the PVID defining the VLAN where incoming frames to port 1 will be assigned to?
This looks to me like an asymmetric VLAN config - something Netgear does not support at all.
