blentz
May 11, 2024Tutor
vlan slow
i have 4 switches 1 in each of 4 buildings. I have the standard default vlan 1 and an additional vlan 10 configured. On switch 1 and switch 4, there is a U port configured for VLAN 10 - on all 4 swi...
- May 12, 2024
That fixed it! - un real - why did it ever work? Crazy technology - switch should not allow that option.
Thank you!
schumaku
May 12, 2024Guru - Experienced User
Exactly, click on the VPN1 port 7 until it shows empty, no [U] or [T], just [ ] .. and apply
blentz
May 12, 2024Tutor
Thank you!
- schumakuMay 13, 2024Guru - Experienced User
Valid point. However, what is named Asymmetrical VLANs (a very niche network design solution in fact) seems still allowed and supported. Unfortunately, there are to many users looking for assistance on similar issues, so it wasn't very difficult for the interested reader to provide a solution here. A warning at least would be helpful, as it's not easy to keep the bigger picture.
Happy your network is working as intended again!
-Kurt.
