Raoulvb
Mar 29, 2022Aspirant
VLAN tagged/untagged processing - CONFUSED
Hi, i have read KBs and some posting in this forum but I am confused on what happens on my network. I have a GS308E and use VLAN 1 as my main network. I also have a VLAN12 for HomeAutomation de...
schumaku
Mar 30, 2022Guru - Experienced User
Is the complete data path for the VLAN 12 configured accordingly tagged - from the router supporting multiple networks and IP subnetworks?
Make the VLAN 12 tagged on the AP IoT VLAN, tagged on the switch port connecting the AP, tagged on the switch port connecting to the uplink router?
Is the DHCP IP coming from the normal LAN IP subnet or from the dedicated and isolated IoT subnet?
Based on the minimal details described it's impossible to help.
Raoulvb
Mar 30, 2022Aspirant
Hi,
thanks for your prompt response.
I am sorry to report that this was my mistake. I had the wrong port in sight. The AP was connected to PORT4 which has VLAN12 tagged.
So all makes sense again, sorry for the confusion.
All ok for this one.
thanks,
Raoul
- schumakuMar 30, 2022Guru - Experienced User
Remeber K.I.S.S. 8-)
