peos42
Nov 19, 2024Tutor
VLAN trunk config syntax using CLI on different switch models
Hi
If I config trunk and access ports like this in CLI in a few netgear switches I have..
interface 1/xg27
description 'TRUNK - VirtServ 3'
switchport mode trunk
switchport trunk native vlan 2027
switchport trunk allowed vlan 2-4,21,899,2027
vlan participation exclude 1,999
exit
interface 1/g10
description 'VLAN 2 - DSC transmitter'
switchport mode access
switchport access vlan 2
exit
How do I config the above in an MS510TXUP that seems to have a not super pleasant CLI according to the CLI PDF i just looked into.
(I am more used to the cisco like syntax used in my older Netgear pro safe switches)
Or can I use the above syntax in a MS510TXUP? I guess I will see when these arrives 🙂
Tnx in advance
//Peo
1 Reply
These MS510TXUP are like all Smart Managed Switches Web and Insight Cloud manged, the CLI is basic, for opertions, not intended for the complete management and administration, as what you might know from Netgear Fully Managed Switches.
