JNBTECH
Feb 07, 2024Aspirant
Vlan/port Setup
Network Setup Fortigate (Firewall) ------> GS752TPV2 ( smart switch) 1 vlan set for VOIP (10.10.2.x) on ports 25-36 port 1 on switch is my trunk port **Issue** I f...
schumaku
Feb 07, 2024Guru - Experienced User
Assuming the native VLAN (something that does not exist on Netgear switches) is the VLAN 1, and more specifically the Access Ports 2...24 and 36...52 (excluding the Tagged port 48): Have an eye on "Configure the PVID settings" on p.171 ff. on 24-Port and 48-Port Gigabit Ethernet PoE+ Smart Switches with 4 SFP Ports User Manual
The PVID does define the VLAN untagged frames flowing into the switch port are associated to.
BrianL
Feb 08, 2024NETGEAR Moderator
Hi @JNBTECH,
Change back the PVID of ports 25-26 to 1 and should be able to receive VLAN 1 in those ports while the said ports will also receive VLAN traffic from your VOIP /or voice VLAN. Give this a try a let us know.
Kind regards,
- BrianLFeb 08, 2024NETGEAR Moderator
Hi JNBTECH,
Are you using voice VLAN? If not and just need these two ports 25-26 tagged (trunk) in VLAN 2, we can change its PVID to 1.
Kind regards,- JNBTECHFeb 08, 2024AspirantI have 9 phones and the PBX I thought of that also. I believe I tried that but it did not work but I will give it a shot once more when I get to the office.
Hi JNBTECH,
Are you using Voice VLAN? MAC Based VLAN? If there are only two VOIPs (Phones) that need to be connected in ports 25-26, we can simply tag (trunk) them on VLAN 2 and leave its PVID to 1. Where the phones will get the VLAN 2 traffic and the PC connected to it will be the native VLAN 1 (Support this setup is a piggy-back setup).
Kind regards,
- JNBTECHFeb 08, 2024AspirantBased off my understanding, the PVID should be two (2) because it needs to match the vlan member. Ports 25-36 are meant for Vlan 2 which is getting the right IPs
- schumakuFeb 08, 2024Guru - Experienced User
JNBTECH wrote:
Based off my understanding, the PVID should be two (2) because it needs to match the vlan member. Ports 25-36 are meant for Vlan 2 which is getting the right IPsYes, this is what I understand from your config, too.
Unclear on how the DHCP server is connected, and what is supposed to provide DHCP for the VLAN 1, subnet 192.168.1.0/24 ... and this is what does not work.
