JNBTECH
Feb 07, 2024Aspirant
Vlan/port Setup
Network Setup Fortigate (Firewall) ------> GS752TPV2 ( smart switch) 1 vlan set for VOIP (10.10.2.x) on ports 25-36 port 1 on switch is my trunk port **Issue** I f...
schumaku
Feb 08, 2024Guru - Experienced User
JNBTECH wrote:
I fail to receive IP's from native Vlan (10.10.1.x) but I get from ports 25-36 which is set for the VOIP Vlan (10.10.2.x).
The DHCP server is on the Fortigate, connected by a trunk, handling both VLANs 1 and 2?
The ports associated as access ports for VLAN 1 (VLAN 1, untagged, PVID 1) can communicate with the 10.10.1.x network devices?
Both the VLAN 1 and 2 tagged as trunk ports are serving DHCP for both subnets?
Or is the DHCP server for the 10.10.1.x subnet probably running untagged on the security appliance, so DHCP requests never reach the DHCP server?
