tonynsx
Jul 05, 2019Luminary
VoIP on GS105Ev2
I have a new GS105Ev2, and I'm trying to setup VoIP on it, but I'm not sure how to. I'm using 802.1Q VLAN. Port 1 = Trunk from another Netgear switch for VLANs 2,4,5 (T) Port 2 = VLAN 5 (U) (Th...
- Jul 05, 2019
Called Netgear, apparently this switch doesn't do voice. Only 8 ports and up does VoIP. Going to return this 5 port and buying the GS308T, which does voice.
tonynsx
- schumakuJul 05, 2019Guru - Experienced User
Of course also the Smart Managed Plus devices can handle voice e.g. on the VLAN ID 5 - however there is no AutoVoice feature to have VoIP devices automatically associated to the voice VLAN.
- tonynsxJul 05, 2019LuminaryThen why is the phone not getting VLAN 5 dhcp? What am I doing wrong? I called netgear support and they said I can’t connect ip phone to this switch. Do I need to tag VLAN 5 on port 2 instead of access (U)? I didn’t try this.
Also this switch doesn’t come up on the smart control center.- schumakuJul 06, 2019Guru - Experienced User
Either the VoIP device must use tagging (and the port must be configired as tagged for the VLAN 5), or the untagged VLAN must be 5 including the PVID - so fixed configuration, no Auto-VoIP - then your device plugged will get an address from the VLAN 5 DHCP.
The Smart Manged Plus are not covered by SCC (as the Smart Manged Pro), the counterpart for these models is the ProSafePlus Configuration Utility.
