tonynsx
Jul 05, 2019Luminary
VoIP on GS105Ev2
I have a new GS105Ev2, and I'm trying to setup VoIP on it, but I'm not sure how to. I'm using 802.1Q VLAN. Port 1 = Trunk from another Netgear switch for VLANs 2,4,5 (T) Port 2 = VLAN 5 (U) (Th...
- Jul 05, 2019
Called Netgear, apparently this switch doesn't do voice. Only 8 ports and up does VoIP. Going to return this 5 port and buying the GS308T, which does voice.
schumaku
Jul 08, 2019Guru - Experienced User
tonynsx wrote:
... now that I think about it, I need to make the port 2, where the VoIP phone is connected into a trunk port.
Netgear does not differentiate trunk vs. access ports - so I guess you talk of a port with one or more purpose configured tagged VLAN - OK.
tonynsx wrote:
I find it weird that I have to use smart control center for some switches, smart wizard for others and prosafe plus for this. It will be nice to use one utility for all switches.
Well, as mentioned before: Two complete different switch classes. Not sure what Netgear does intend to do mid- and long-term ref. the two SCC and the ProSafe Plus utilities. Potentially both will tend to be phased out in favour of the Netgear Switch Discovery Tool (which does list both Smart Managed Plus and Smart Managed Pro, but not the Insight managed switches however [another inconsistency, not all Insight GCxxx switches are under Insight Management] and using the individual switch Web UI only.
tonynsx
Jul 08, 2019Luminary
I made port 2 tagged for VLAN 5 and the IP phone is getting dhcp and working. Thanks for your help.
