Tbelliboston's avatar
Tbelliboston
Follower
Apr 03, 2022
Wac505 offline for 5 minutes every hour
I have 2 wac505 APs. Both are connected to the same Poe switch. One goes offline every hour and comes back online after 4-5 minutes. Both have firmware 9.5.5.4
They are both set to the same Sid, so it is hard to say if the one AP is actually not broadcasting, since internet connection is still on for that sid.
I also have a nighthawk router on a different sid that is functioning fine.
Thoughts or suggestions would be appreciated.
  • plemans's avatar
    any chance you have an external power supply you could try on it?
      • schumaku's avatar
        schumaku
        Among the logs I've suggested before. Management -> Monitoring -> Logs and then [Download Detailed Logs]
        A simple search in the fine documentation would certainly help - start from https://www.netgear.com/support/product/WAC505.aspx
        The GS108PEv3 is a simple Web configurable switch, not. Smart Managed switch, and then not Cloud Manageable. At no point (leaving the hint from the Quick Start Guide that the Insight App can be used to discovery, find the IP and serial number for the product registration) Netgear does state the GS108PEv3 (or any other Web managed, formerly designated Plus Managed) are can be managed by any App.
  • Another bit of info - the poe switch is a Netgear GS108PEv3 that is not able to be managed with app
ProSupport for Business
