slamers74
Apr 07, 2020Aspirant
WAC510 Multiple SSID on separate VLAN using Smart Switch GSS116E
First - I am new to VLAN setup and smart switch configuration, though I have some background and understand the goal and purpose of them. My ultimate goal is to end up with multiple VLAN's to cr...
- Apr 09, 2020
- If I change to 802.1q, and setup the VLAN's mentioned like I have, and then setup them all as 'untagged' - is that basically the same functionality/configuration as I have with just the 'Advanced Port Based VLAN' setup?
Yes. Untagged ports or "access" port accepts traffic for only a single VLAN. The devices that you will connect to the untagged ports are VLAN-unaware devices such as computer and printer.
- So if I set the switch to T for the WAP port - then I assume when I setup the additional wireless on the WAP - I set the VLAN ID for those to match my VLAN's?
When you set up additional wireless networks (or SSIDs) on the WAC510, you can set the corresponding VLAN ID to match the respective VLAN set on the GSS116E.
- What happens if I have a hard wired PC that I want on multiple VLAN's?
Are you referring that the PC is connected to a tagged port? If yes, you must configure a VLAN ID on the network interface controller (NIC) of the PC.
Let me share the article below:
What do I need to know about setting up VLANs?
- The home router seems to have an option for VLAN - with VLAN tag groups - could I take the dirty approach and simply setup the four LAN ports and assign the 4 VLAN's to them and then run them all to my switch (I know - it would take multiple ports on the switch).
As far as I have checked, there is no option on the R6400 to create a DHCP server for the VLANs configured on the GSS116E. I'm not familiar on how VLAN tag groups work on the R6400. You may post this on the NETGEAR Home Community under the General WiFi Routers board here.
- Can you manage the the BR500 VPN with just a web browser (I am not interested in the Insight solution).
Yes, it can be managed through its web-GUI using we browser.
DaneA
NETGEAR Community Team
DaneA
Apr 08, 2020NETGEAR Employee Retired
Welcome to the community! :)
- Do I need to leverage something with 802.1Q and tagging? I don't have that turned on and not sure where/how to start.
It would be best that you configure 802.1Q VLANs on your GSS116E. The port where the WAC510 is connected to the GSS116E should be a member of all VLANS and must be set as a tagged (T) port with a PVID of 1.
Let me share the articles below as your guide in setting up 802.1Q VLANs in the GSS116E:
How to configure VLANs on a ProSAFE Web Managed Plus Switch with shared access to the internet
How to configure an 802.1Q VLAN on a ProSAFE Web Managed Plus Switch using the web interface
- I considered having another router serve as a separate DHCP server for the guest network, but assume I don't need to do that and that the smart switch and SSID separation will keep my work separate from guests and other outside stuff.
As far as I know, the R6400 doesn't support VLAN nor any NETGEAR Home Router model. It would be best that you deploy a router that is capable of VLANs as well in order to fully implement the network you want to setup. I suggest you the BR500 which supports VLAN. To know more about its specifications, kindly check its data sheet here.
Just to inform you, both BR500 and WAC510 can be managed via NETGEAR Insight. To know more about NETGEAR Insight, click here.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
slamers74
Apr 08, 2020Aspirant
Thanks for the quick feedback. I am trying to learn about tagging, not tagging, default tagging.
So a few follow up questions:
- I had passed through the articles you mentioned, but will look at them again.
Thanks again.
- DaneAApr 09, 2020NETGEAR Employee Retired
DaneA
- slamers74Apr 09, 2020Aspirant
Thank you so much for the information. I think this will help and will make some changes and test when I my connection has some down time.
