btbmert
Nov 09, 2018Aspirant
Web Management Restriction
Hi All,
Since there is not any console management port (RS232, etc) on XS708T, we need to secure web management acces. Is it possible to access web management just only from a single assigned p...
- Nov 11, 2018
Hi btbmert,
Welcome to the community! :)
I suggest you to create a Management VLAN and assign at least one port. Kindly read page 40 and pages 125-132 of the XS708T user manual here about Management VLAN and Configuring VLANs respectively.
See the articles below and use it as your guide:
How to create Layer 2 VLANs on NETGEAR ProSAFE Switches
DaneANETGEAR Community Team
DaneA
Nov 11, 2018NETGEAR Employee Retired
Hi btbmert,
DaneA
- DaneANov 14, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- btbmertNov 14, 2018Aspirant
Hi DaneA,
Thank you for your follow-up. Sorry for not replying but we are working on this and I hope it will work. I will let you know the result or further detailed questions.
Best Regards,
