Adnim's avatar
Adnim
Star
Sep 20, 2022
Which is the best Netgear switch to handle POE and non-POE devices, only need 5 ports
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Adnim,
    In the NETGEAR Smart Managed Pro switch category, there is no 5-port switch model that supports PoE.  You may want to consider the GS110TPv3 switch wherein all of its 8 Gigabit ports supports PoE.  To know more about the specifications of the GS110TPv3 switch, kindly check its data sheet here.
    Furthermore, you may want check other NETGEAR Business Switch models that supports PoE that might also fit your network requirements from the link below:
    NETGEAR Switch Selector
    DaneA
    NETGEAR Community Team
ProSupport for Business
