ChrisMayers
Mar 03, 2026Tutor
Which Managed Switch Range?
Hi, Hopefully a very simple question. We are looking for 2 small managed PoE switches (ideally 1x8 port and 1x16 port). However, we're a bit confused by the various models and product ranges. Th...
ChrisMayers
Mar 03, 2026Tutor
Hi, Thanks very much for your reply! I did see these, and think they'll do the trick, but I was really hoping for something smaller than 24 port though as 16 is a bit bigger than we really need. Off the top of my head, I think there are about 12-14 connections required including the LAG connection back to the main switch... I've struggling to find anything between 10 ports and 24 ports with the necessary depth of configuration though. I guess having plenty of scope for expansion is never a bad things though...
Would anyone be able to post me a screenshot of a typical config screen for one of these - ideally the vLAN page. We need the more advanced vLAN settings that allow assigning of vLAN to LAGs, and also LAGs need to support LACP
Thanks again,
Chris.
Mar 03, 2026Guru - Experienced User
ChrisMayers wrote:Would anyone be able to post me a screenshot of a typical config screen for one of these - ideally the vLAN page.
No screenshots (I have a different switch). But manual links might help:
- https://www.downloads.netgear.com/files/GDC/GS324TPv2/GS324TPv2_GS348TPv2_UM_EN.pdf
- https://www.downloads.netgear.com/files/GDC/GS310TPv2/GS310TPv2_UM_EN.pdf
