Ur25v's avatar
Ur25v
which SFP module and fiber types are compatible with the GC 110 switch
Where can I find with SFP modules and which fiber types are compatible with the GC110 range of switches?
  • schumaku's avatar
    schumaku
    GC110, GC110P, GC510P, GC510PP Data Sheet p.17 does describe the (supported) modules:
    Optional Modules and Accessories
    AGM731F-10000S SFP Transceiver 1000BASE-SX (Short range, multimode)
    AGM732F-10000S SFP Transceiver 1000BASE-LX (Long range, single mode)
    AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC
    • marvalj's avatar
      marvalj
      However in the user manual there is a table where 10G is supported, but no sfp+ 10G is listed?
      GC110P Eight PoE 10/100/1000Mbps ports
      Two 10G/1G SFP+ ports
      • schumaku's avatar
        schumaku
        Looks like a mistakte to me - there are no SFP+/10G cabable ports on the GC110xx/GS510xx.
  • Also the firmware seems to block non Netgear branded modules (I tired some Netgear flashed BX-transceivers from FS.com an whyle they are recognised (otheres are just rejected) there is still no link-up detected by the switch.
    • Ur25v's avatar
      Ur25v
      10Gtek modules work fine with the GC110 models.
      • 60 USD + shipping for a pair, damn, are those made of gold.
        I only paid 40€ for the GC110P...
ProSupport for Business
