hosregla
Dec 04, 2016Aspirant
wired router and 5 switches
Hello guys how is the best wired. i have ffth with AMPER eg-663 WIRED: G01 EG-663 ---> RACKG SWG (.203) G01 40m G02 EG-663 ---> RACKAB SW (.200) G01 38 m ------> SWB (x.201...
- Jan 04, 2017
It seems that your goal in setting up LACP is to improve the read/write speeds between PCs, am I right? It seems your concern is similar to this forum link I found online. Kindly access and read it.
Doing an iPerf test would help. Here are the links I found online that you could use as a guide to perform an iPerf test.
What is iPerf and how is it used?
Basic Network Testing with iPerf
DaneA
NETGEAR Community Team
DaneA
Dec 05, 2016NETGEAR Employee Retired
Hi hosregla,
Are you going to cascade all of the switches having a LAG configuration in between?
Kindly access the links below as reference guide on how to configure LAG:
Configuring the Link Aggregation Group (LAG)
How to set up Link Aggregation
DaneA
hosregla
Dec 05, 2016Aspirant
Will I get better performance, if the switches do not go through the router, and only one of them goes through the router ?.
The DC, and SQL SERVER, PACS DICOM are connected in 192.168.0.200 GS748Tv4H1 5.4.2.13
How would you connect them?
Can I connect two switches in lag mode with x.200?
Thnks by your time ;)
- hosreglaDec 06, 2016Aspirant
i have find this KB http://www.downloads.netgear.com/files/GDC/GSM7352SV2/how_to_configure_lag.pdf
but what is the best practice? 1º each switch to router or 2º each switch, in cascade by LAG sw1 ---LAG 2 wired-- sw2 ---LAG 2 wired SW3 -- LAG 2 wired SW4 -- (DC,SQL SERVER 2012,DICOM PACS are in sw 1.
- DaneADec 06, 2016NETGEAR Employee Retired
Hi hosregla,
Referring on the diagram below, I believe this is the setup that you wanted to implement wherein Switch A is connected to the firewall router. Then switch B is connected via a LAG connection to Switch A. Then Switch C is connected via a LAG connection to Switch B. Am I right?
If ever I am right, this setup is possible and you may refer on the article I have provided previously on how to set up LAG.
Regards,DaneA
- hosreglaDec 07, 2016Aspirant
The best practice is your scheme. my question is.
Is it good practice, connect to b by LAG and C connecto to A by LAG and D to B by lag ??
