hosregla
Dec 04, 2016Aspirant
wired router and 5 switches
Hello guys how is the best wired. i have ffth with AMPER eg-663 WIRED: G01 EG-663 ---> RACKG SWG (.203) G01 40m G02 EG-663 ---> RACKAB SW (.200) G01 38 m ------> SWB (x.201...
- Jan 04, 2017
It seems that your goal in setting up LACP is to improve the read/write speeds between PCs, am I right? It seems your concern is similar to this forum link I found online. Kindly access and read it.
Doing an iPerf test would help. Here are the links I found online that you could use as a guide to perform an iPerf test.
What is iPerf and how is it used?
Basic Network Testing with iPerf
DaneA
NETGEAR Community Team
hosregla
Jan 04, 2017Aspirant
i have the same result with LACP without LACP.
DaneA
Jan 04, 2017NETGEAR Employee Retired
DaneA
- hosreglaJan 04, 2017Aspirant
Obviously if NETGEAR FORUM says that I put LACP, instead of STATIC, I put LACP.
I completely understand that a test of velocity measurement, between two points, is very simple, and that there must be deeper tests.
Thnks by your knowledgebase!!!!
