Matts423
Mar 02, 2025Aspirant
Wirless devices can't connect to wired devices on home network
Hello, I'm having an issue where nothing wireless can talk into or see anything wired on my network (everything is on the same subnet). ISP (verizon) ONT connects to -> SXR80 Mesh system (wit...
Mar 02, 2025Guru - Experienced User
What happens if you connect your wired devices directly to the SXR router?
- Matts423Mar 03, 2025Aspirant
Nothing Wired or Wireless will go through the SXR router/satellite to the GS728. Internet passes through it and devices on the main switch can see/ping devices on the SXR system.
- FURRYe38Mar 03, 2025Guru - Experienced User
Ok, lets take the GS out of the mix. Does wireless and ethernet connected devices communicate while only connected to the SXR?
