coxbuell
Sep 17, 2025Tutor
XS716T to XS712T with SFP+ and fibre
Hi, I need to plug XS716T and XS712T with SFP+ and fibre. I bought 2 x SFP+10G and fibre câbles. But it does not work (no lights speed). Do I have to activate something? I already te...
coxbuell
Sep 18, 2025Tutor
Hi,
Thanks for your answer.
I got LC multimode SFP+ 10G (ipolex) + LC-LC (UPC) fiber.
I tried a loopback test with no result.
Initially, I tried to connect 2 switches : 1 x XS716T + 1 x XS712T
Both switches are update with last firmware present on Netgear.
However, NEêtgear does only support the original Netgear modules as specified with each switch model.
I believe I don’t have the correct module.
I just order “NETGEAR AXM761 Compatible Module SFP+ 10GBASE-SR”.
Hoping it will work!
Thanks for your help.
Best regards.
NC
