pgarciap
Apr 20, 2020Aspirant
XS728T 28Port+4SFP+ is a stacable switch?
Hello, We have two switches "XS728T 28Port+4SFP+". We wanted to ask if we can configure both in stack mode. We can't find on datasheet about this feature on this model. Regards,
- Apr 20, 2020
Welcome to the community! :)
I'm afraid to inform you that the XS728T does not support stacking. Since you are looking for a Smart Managed Pro Switch Model (like the XS728T) that supports stacking, I suggest you either the S3300-28X or S3300-28X-PoE+ switches.
Both the S3300-28X and S3300-28X-PoE+ have 2 stacking ports. The only difference between the two switches is that the S3300-28X-PoE+ supports PoE+ on all 24 ethernet ports. To know more about the specifications of both S3300-28X and S3300-28X-PoE+, access their data sheet here.
Furthermore. NETGEAR has a vast variety of business switches that supports stacking. Kindly access the links below to know more:
NETGEAR Business Switch Selector
NETGEAR Business Product Catalog Volume 20-1
DaneA
NETGEAR Community Team
DaneA
Apr 20, 2020NETGEAR Employee Retired
DaneA
pgarciap
Thx for the quick answer!!
