DRUMDUDESAN
Mar 23, 2017Aspirant
XS728T and Multicast
Hi, I need to know if the model XS728T supports and handle true multicast traffic? Some lower end switches convert multicast traffic to broadcasts. If not which model of switch that has 24 ports a...
- Mar 23, 2017
Hi Jeff
In a M4300 stack, firmware upgrade can be differed, but a maintenance window will be required as the whole stack must reboot at some point.
I mean that new firmware can be imported into the master switch, and chosen as new image <<across the stack>>.
But the upgrade itself requires a reboot.
In your second scenario, if one switch in the stack gets upgraded separately, it won't join the stack back, due to code mismatch.
DRUMDUDESAN
Hi,
One more question.
If I stack these switches and require a firmware update:
- will the whole stack reboot?
- or can I patch/firmware one switch at a time and reboot individually?
Thanks
Jeff
LaurentMa
Mar 23, 2017NETGEAR Expert
Hi Jeff
