Squuiid
Jul 07, 2023Luminary
XS728T fan replacement options
I wanted to create a post to help anyone looking for replacement (quieter!) fans for the XS728T switch. While the XS716T and XS708T are easy, with direct Noctua swap ins, the XS728T is an entirely di...
BrianL
Jan 16, 2024NETGEAR Moderator
Hi Cpgeek,
Please do check our warranty terms and conditions from this page https://www.netgear.com/about/warranty/ regarding modifications.
Kind regards,
