gorkatjimmies
Dec 02, 2020Aspirant
XS748T Reboots randomly
XS748T ProSAFE 48-Port 10-Gigabit Smart Managed Switch,6.5.1.22,1.0.0.0 I have an issue where this switch randomly reboots. It seems to happen every couple of weeks to as often as every co...
DaneA
Dec 03, 2020NETGEAR Employee Retired
Found out from the NETGEAR Support Team that you have already opened a support ticket with them. You may want to post here the progress of it.
DaneA
NETGEAR Community Team
- schumakuDec 03, 2020Guru - Experienced User
gorkatjimmies Have multiple LAGs configured, and have e.g. STP, RSTP or MST enabled? These combinations will lead to the crashes almost reliably.
DaneA We're fighting with this issue now for more than one year. Kevin Hong has duplicated our set-up and confirmed the issue some weeks ago.
- gorkatjimmiesDec 03, 2020Aspirant
This is definitely our situation. Two lag ports and RSTP. Support gave me a few items to try related to making sure the device wasn't randomly losing power. I will try those when everyone is off the network. Will also see if we need the two LAG ports.
