DILVISH
Sep 15, 2025Tutor
KERNEL ERRORS on WAX214
 Hello !
 Since the last firmware update, I get these errors on my WX214 antenna.
 The antenna works, but some peripheral (wifi camera) disconnect regularly (they are next to the antenna 5 -...
schumaku
Sep 15, 2025Guru - Experienced User
This log is completely volatile. After a reboot, there won't be any signs of the disconnection.
Grab the log file -after- that or these wireless devices are de-associated.
Is this one of the newer WAX214v2 model https://www.netgear.com/support/product/wax214v2/ or the earlier WAX214 version https://www.netgear.com/support/product/wax214/ ?
For completeness, include brand, model, and firmware version of the WiFi camera.
