DILVISH
Sep 15, 2025Tutor
KERNEL ERRORS on WAX214
Hello !
Since the last firmware update, I get these errors on my WX214 antenna.
The antenna works, but some peripheral (wifi camera) disconnect regularly (they are next to the antenna 5 -...
Sep 15, 2025Guru - Experienced User
Those are KERNAL errors. System level.
Have you factory reset the WAX and setup using a wired PC and web browser with the AP connected to a host router?
DILVISH
Sep 18, 2025Tutor
no, as I have only a deco problem with one peripheral, I choose to wait and decided to change the camera instead.
