ZBlank
Jun 16, 2023Initiate
Nighthawk x6 - Airbridge wbc502 - r7900 in AP mode
Have NH x6 router as Home network tied thru Airbridge WBC502 to Shop that has R7900 in AP mode. Have two Wi-Fi stations (home, shop) setup. Has worked great for last 5 years. Recently I have built Gol...
Jun 16, 2023Guru - Experienced User
It should be able to.
The wbc502 is ran into the R7900's wan port?
And then from there you connect the wired devices to its lan port?
Have you tried other devices?
ZBlank
Jun 17, 2023Initiate
I have R7900 I think on Lan port. I will try this to see if it fixes problem. Get back to after wards
