SMcM86
Dec 22, 2025Aspirant
WAC124 AP/router - cannot login
We have two WAC124s, both configured as access points and connected via ethernet to the router. These were straightforward to configure when we bought them and have worked well. However I recently t...
schumaku
Dec 24, 2025Guru - Experienced User
Typical "issue" when operating these WAC124 (or similar) in Access Point Mode - you can't use the http://routerlogin.com/ First reference to this is in the fine WAC124 User Manual https://www.downloads.netgear.com/files/GDC/WAC124/WAC124_UM_NEW_EN.pdf p.18.
- SMcM86Dec 30, 2025Aspirant
Thank you both. Unfortunately I have already tried both these options, basically logging in via the device's IP address.
Both the WACs have been working fine, and still are, since they were set up about three years. I only tried to login to update the firmware, to find neither device could be accessed. I'm struggling to believe that both devices developed the same fault at the same time so I'm wondering if Netgear has changed the login process or criteria?
Many thanks.
