SMcM86
Dec 22, 2025Aspirant
WAC124 AP/router - cannot login
We have two WAC124s, both configured as access points and connected via ethernet to the router. These were straightforward to configure when we bought them and have worked well. However I recently t...
schumaku
Dec 24, 2025Guru - Experienced User
Typical "issue" when operating these WAC124 (or similar) in Access Point Mode - you can't use the http://routerlogin.com/ First reference to this is in the fine WAC124 User Manual https://www.downloads.netgear.com/files/GDC/WAC124/WAC124_UM_NEW_EN.pdf p.18.
