Oldboyracer's avatar
Mar 07, 2018
100 mbps between GS605AV & GS108v3
Hi Guys & Gals, I have cascaded a GS605AV & GS108v3 but only acheiving a speed of 100 mbps between them.What I have done so far :- 1) My set up is ISP modem > GS605AV > GS108v3. I have swapped the ...
  • Oldboyracer's avatar
    Oldboyracer
    Apr 03, 2018
    I thought I would update with my solution to the problem. Firstly I'm an absolute newb when it comes to networking, it being my 1st attempt. I won't bore you with the details of my stumblings I did find an answer probably forced on me by other problems.
    My situation - 3 storey house, 3 PC's & a wireless router on top floor, my PC on lower ground, 7 devices & a wireless router (old ISP router) on the ground floor. I purchaced an Asus RT-AC88U as it has 8 LAN ports this does the wireless duties for the ground & lower ground floors (ISP wireless now redundant). I already had an Asus RT-AC66U which will do the wireless duties upstairs. The GS108v3 now serves the 3  PC's upstairs & the GS605AV 3 of my 4 devices in my home theater. All other devices + the 2 switches are connected directly to the RT-AC88U & so far all OK except for a couple of dodgy cables that I have replaced. The ISP's wireless router had a pitiful range so I needed to do something about that anyway, fingers crossed no more problems.
ProSupport for Business
