usao
Dec 23, 2016Aspirant
2x gs116 wont link
I have 2x GS116 switches. The first is my primary switch, out of the router. The second is in my server room, and port 1 is connected with a straight-through cable to the second. It will not link ...
DaneA
Dec 25, 2016NETGEAR Employee Retired
Hi usao,
Welcome to the community! :)
Kindly answer the questions below:
a. Is the primary GS116 connected to a port on a wall that connects to a port on a wall in the server room where the second GS116 is deployed? Or, are the primary and secondary GS116 switches connected directly to each other?
b. Have you tried changing the ethernet cable connecting the primary and secondary GS116 switches to isolate the problem?
c. Have you tried to swap the primary and secondary GS116 switches in order to isolate the problem?
I look forward to your response.
DaneA
NETGEAR Community Team
