usao
Dec 23, 2016Aspirant
2x gs116 wont link
I have 2x GS116 switches. The first is my primary switch, out of the router. The second is in my server room, and port 1 is connected with a straight-through cable to the second. It will not link ...
DaneA
Dec 27, 2016NETGEAR Employee Retired
usao,
Kindly try to use a crossover cable between the 2 GS116 switches. Let us know the results.
DaneA
NETGEAR Community Team
usao
Dec 28, 2016Aspirant
Ive ordered a crossover adapter from ebay, will take a week to get here.
However, reading GS116 docs indicate it supports auto uplink.
Auto Uplink™ automatically adjusts for straight-through or crossover cables
- DaneADec 29, 2016NETGEAR Employee Retired
I apologize for this. I did not mean that you will have to buy a crossover cable.
I assumed that you already have a crossover cable or will make a crossover cable out of the typical ethernet cable. You are right that the GS116 switch supports Auto Uplink. However, by the time I have read your reply, I have thought to isolate the problem by using a crossover cable. That is why I suggested it in order to isolate the problem since swapping the 2 GS116 switches (as I have also suggested) would involve an outage as you have mentioned from your previous reply.
DaneA
