usao's avatar
usao
2x gs116 wont link
I have 2x GS116 switches. The first is my primary switch, out of the router. The second is in my server room, and port 1 is connected with a straight-through cable to the second. It will not link ...
  • DaneA's avatar
    DaneA
    Jan 01, 2017
    @usao,
    It seems that the new GS116 is faulty.  I suggest that you return it from the store where you bought it and asked for a replacement.
    DaneA
    NETGEAR Community Team
ProSupport for Business
