usao
Dec 23, 2016Aspirant
2x gs116 wont link
I have 2x GS116 switches. The first is my primary switch, out of the router. The second is in my server room, and port 1 is connected with a straight-through cable to the second. It will not link ...
DaneA
Jan 04, 2017NETGEAR Employee Retired
usao
Jan 04, 2017Aspirant
Well, further testing showed that the problem is with the ports on the left side of the switch.
I was not able to get any lights from hosts or the uplink on the left side, but the ports on the right side did work.
I contacted the seller on ebay and he agreed to a return.
So, I believe the switch is defective.
- usaoJan 08, 2017Aspirant
Yes, I was able to return the switch.
However, I located a switch from another vendor.
- DaneAJan 09, 2017NETGEAR Employee Retired
That's alright. Thanks for the update. :)
Since we have isolated the problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
