williwow
Apr 04, 2016Aspirant
Additional switch breaks network performance/connectivity
Hi Community and Experts! I have a strange problem: adding an additional switch breaks (totally) network performance. This is my setup: * central FTTH router (DHCP server) - connection to...
- Apr 12, 2016
Hi williwow,
I think having a packet capture using Wireshark would help isolate the problem as to why the problem happens only when the GS105v5 is connected but not on the GS108v3. I suggest that you install Wireshark on your PC(s)/laptop(s) to capture packets. Kindly download Wireshark from this link. You may use this link as reference guide on how to use Wireshark.For the captured packets to be analyzed, kindly open an online case with NETGEAR Support regarding this problem. Then, attach the captured packets from Wireshark via the online case you have opened for it to be forwarded to the engineering team and be analyzed.Regards,DaneANETGEAR Community Team
williwow
Apr 12, 2016Aspirant
Hi DaneA,
no - I am out of switches :-)
Prior to the GS105 I tried this model from D-Link: DGS-105/E 5-Port Layer2 Gigabit Switch. As this switch showed the problems described I sent it back to the seller and purchased the more expensive Netgear GS105 hoping that it would perform well. Unfortunately the GS105 showed the same problems. I have no other device to test on. It's very strange that the GS108v3 works whereas the GS105v5 in this configuration not.
Now I am using the GS105 in my home office and the GS108v3 connected to the dreambox receiver. Everything is fine, but it is not satisfying that the root cause is still unclear. Maybe the v5 models have a latency problem? The throughput in my home office setting is OK.
Thanks
Williwow
DaneA
Apr 12, 2016NETGEAR Employee Retired
Hi williwow,
DaneA
- williwowApr 12, 2016Aspirant
Hi DaneA,
Good idea - it will take me some time to do this analysis and forward it to support. For the time being I will close this thread, and thanks for your immediate and good suggestions! (Basically the idea of swapping the switches kept me going again).
thanks
Williwow
