Zelf24
Aug 28, 2015Aspirant
Cable Modem > Airport Express > GS108 Switch, but not Cable Modem > GS108 Switch > Airport Express?
So it appears that my Apple Airport Express router is being a bit of a diva. I have a Motorola SB6141 Cable modem running into my Apple Airport Express which runs into my Netgear GS108 Gigabit switc...
- Aug 31, 2015
Hello Zelf24,
Regarding this statement below:
Zelf24 wrote:
When my connection is Cable Modem>GS108>Airport Express, I can get a 1.0 gbps-link from my cable modem and working internet on an ethernet-plugged PC/Mac (which is directly plugged into my Netgear gigabit), but the Airport Express cannot pull an IP address. When I put the Airport Express first in line from the modem, then connect the Netgear to it, the Express works wonderfully, and the Netgear works and negotiates gigabit between devices internally (just no gigabit link light from the modem first in line).
This is normal, a regular modem only provides a single IP address (unless you bought public IPs and the modem can handle giving out more IP or on DHCP mode) so the first device connected to it which is the PC will obtain that IP. It is the reason why the Apple Airport Express does not get an IP anymore. If you only have a single IP provided by the modem, all other ports of the switch will be unuseable. Have you tried connecting Modem>GS108>Airport Express without any other devices (like PCs) connected to the switch? I believe that setup will work, but then again all of the other ports will be unuseable since there is only a single IP from the modem.
I'll look forward to your response.
Thanks,
Zelf24
Aug 29, 2015Aspirant
JohnRo,
I just verfied your inquiry once again:
I'm paying for 30 mbps down / 5 mbps up on my cable internet package. My intent in purchasing a gigabit switch wasn't necessarily to speed up my internet connection, but to allow more bandwidth total between all of my devices (of which there are probably 20 on my LAN). Within my LAN, I do a ton of external/internal HD video-streaming, etc- so I just wanted to "widen the roads" so to speak, as things were beginning to feel a bit crowded.
The only way that my Airport Express ever seems to work correctly, is if it gets to connect immediately from the modem, and then the Airport Express's extra ethernet pass-through then goes to my Netgear switch.
Of course, under this condition my cable modem only sees what is locally connected to it, and that is my non-gigabit capable Airport Express (which created a Fast Ethernet-Only activity light on the modem).
Sorry if this reply seems a bit redundant, I wrote it over the course of two different times of the day.
Thank you for your help, JohnRo!
JohnRo
Aug 31, 2015NETGEAR Employee Retired
Hello Zelf24,
Thanks,
- Zelf24Sep 06, 2015Aspirant
Thank you JohnRo. Your theoretical setup (of connecting the Airport Express first to my gigabit switch) will indeed work, but as you can imagine, that connection would be haphazard at best. I have marked your response as the accepted solution. I do appreciate your time and will just have to deal with my wifi "non-giga / fast ethernet-only" connection as it stands in it's current form.
I appreciate your thoughts and helpful advice! Take care.
- JohnRoSep 07, 2015NETGEAR Employee Retired
Hi Zelf24,
You're welcome!
If you wanted to get the gigabit connection from the modem and have the current setup, then you will have to eliminate the GS108 and use a gigabit router like the FVS318G.
Thanks,
