FigLeaf
Jul 25, 2019Aspirant
Cannot Factory Reset ProSafe GS108
hello everyone, I am having a hard time resetting my ProSafe 8 ports Gigabit Switch (GS108). I can't find the reset button anywhere. I cannot find the IP address using the SmartWizard Discovery ...
- Jul 25, 2019
No IP assigned at all, no management access of any kind.
schumaku
Jul 25, 2019Guru - Experienced User
That's a little bit difficult because of this GS108 is a non-managed switch - noting to reset.
What's the problem with it?
- FigLeafJul 25, 2019Aspirant
oh I see. When you say it is an unmanaged switch, there is no way I can open the browser page for it right? So it will always be given an IP address by the DHCP?
I wanted to set a static IP address for it that's all.Thanks for the help.
- schumakuJul 25, 2019Guru - Experienced User
- FigLeafJul 26, 2019Aspirant
Perfect!!! Thanks a lot schumaku for the orientation.
The switch works well. I have it running right now. No static IP though; but I guess that's okay.
I never would have thought it was an unmanaged switch 'cause I don't know much about switches. I am quite new to networking and it has is a learning curve, but I intend to keep gaining more knowledge from others as well.
Thanks again man. Bless up.
