cdmiller's avatar
cdmiller
Can't login from Prosafe 2.3.5 after 2.0.1.40 firmware update
Today I received a security alert from Netgear about older verions of Prosafe.  So, I went online to check out my version.  While I was on the latest version of Prosafe, I saw that I was not using the latest firmware (2.0.1.40).  I was using 2.0.1.26.  So, I updated the firmware.
Since doing so, I am not able to login using the Prosafe utility.  I get the message "Login Command is not supported by agent!".  I am able to login from Firefox using the switche's IP.
After quite some time, I've powered off the switch in hopes I could login.  But to no avail.
Has anyone else had this problem?  Any suggestions?
Thanks,
Chris.
    • cdmiller's avatar
      cdmiller
      Upgrading to Prosafe 2.4.3 resolved this problem.  I should have tried that first.  I can no login successfully from the utility.  Thank you for your help.
      • XavierLL's avatar
        XavierLL
        NETGEAR Employee Retired
        thanks cdmiller to let us know :)
        Enjoy your Plus Switches!
        Regards
        Xavier Lleixa
        NETGEAR CBU PLM
  • I am having the exact same experience. I can login when using Firefox but in Chrome there is no input box for the password field after updating the firmware to 2.0.1.40 from 26.
