LevelUpLiam24
Sep 07, 2021Apprentice
Connecting two GS305P to extend network
Hey all, I think this is possible, but I want to avoid any diminishing return this may cause as I want to keep my ping low for gaming. I want to extend my network range without getting longer cat ...
JohnC_V
Sep 08, 2021NETGEAR Employee Retired
It should work just fine. You can also use the GS305P to power up the other one. If you run into some issues, please call NETGEAR support so that they can help you immediately with your problem.
John
NETGEAR Community Team
- schumakuSep 08, 2021Guru - Experienced User
Connect: Yes. Power: No - lack of the GS305P and the like don't have a PD port to power the switch.
On modern switches, you always have a switching capacity covering end to end, so each port can reach full wire speed while communicating with other ports. When doing a cascade, one this connecting link does limit the maximum available speed between the two switches ports. When linking up two GS305P, the link (or trunk) is 1 Gb, while you have four GbE ports on each switch available. Say you operate a backup from a port on switch #1 to a NAS on the switch #2, this trunk link could reach the full capacity of the Gigabit cascading link, while connections between the two switches share the limited cascading link. If you compare now with a single eight-port or bigger switch, this limitation does not apply. There is full end-to-end capacity available.
