PeterJWag
Dec 03, 2018Aspirant
Connectivity of a gigaswitch and an Access Point
Good Afternoon,
I have connected the gigaswitch to the router, to increase the number of ports available for connecting devices.
I have just discovered Access Points and want to use an AC21200 Mb...
- Dec 04, 2018
For really pushing things to the top, two Ethernet cables would be great, one for the WAC, one for the STB.
PeterJWag
Dec 04, 2018Aspirant
Thanks Schumaku. Do I understand you correctly, then, that the ethernet ports on the WAC104 are not good enough to support fast connection for the TV box> Also, am I right in understanding that the WAC104 is better connected directly to the router than the gigabit sitch?
schumaku
Dec 04, 2018Guru - Experienced User
