Mathy1's avatar
Mathy1
Does the GS108v4 support PoE?
Hi All Just a quick question, can the GS108v4 support Poe. Many Thanks..
  • DaneA's avatar
    DaneA
    Jul 07, 2019
    Mathy1,
    If you are looking for an 8-port Unmanaged Gigabit PoE switch, I suggest you either the GS108LP or GS108PP.  Both of the GS108LP and GS108PP switches supports PoE/PoE+ on all 8 ports.  The main difference between the two switches is that the GS108LP has a PoE Budget of 60W while the GS108PP has a PoE Budget of 123W.
    For more information about the GS108LP and GS108PP switches, kindly check the data sheet here.
    For a list of NETGEAR PoE switches that might fit your network requirements, check the links below:
    Power over Ethernet Switches
    NETGEAR Business Product Catalog Volume 19-1 - see page 23
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
