homedad54
Nov 13, 2021Follower
Ethernet connected but no internet Eero Pro 6
I've been using a Netgear GS108 switch with my Eero Pro6 router with a fiber line optic service. I was able to connect the switch and printers to the network for months but suddenly all the devises c...
DaneA
Nov 16, 2021NETGEAR Employee Retired
Welcome to the community! :)
Just to clarify. If you connect a PC directly to your Eero Pro6 router, are you able to access the internet via a wired connection? If not, you will need to contact your Internet Service Provider.
Is the GS108 directly connected to the Eero Pro6 router?
DaneA
NETGEAR Community Team
